Kreeka ralli 2004 - III päev
veteran
Postitus Postitas veteran »
Hommikut. Eilse juurde veel tagasi tulles, kui Solbergile trahv anti,siis mõtlesin et kust selle suurus pärit võib olla. Sellist karistust pole sellise vea eest ette nähtud. Ka WRN-s on sama mõte üleval.
:twisted: Solberg penalty - No Subaru appeal but an apology
5 Jun, 20:13
The Subaru team issued an apology to it's World Champion this evening following the award of a 30 second penalty to him earlier in the day.
"In response to the news that rally leader Petter Solberg had been given a 30 second penalty because his Subaru Impreza WRC had no rear mud flaps when leaving service this afternoon, Team Principal David Lapworth commented:
"On behalf of our team I would like to apologise to World Champion Petter Solberg that a minor technical infringement has resulted in a halving of his rally lead. An oversight in not refitting the mudflaps provided no competitive advantage whatsoever and occurred when replacing the damaged rear bumper of his car.
We hope that the penalty will have no bearing on the result of this rally"
Statement ends
It is noteworthy that there is apparently no prescribed penalty for this (and a number of other) offences. Theoretically it would have been possible for the Stewards to have excluded a car for this offence.
Whether or not the penalty affects the outcome - and it is difficult to believe that Solberg will not be under greater pressure and his pursuers greatly encouraged by this penalty - it would suggest that this, and a number of other regulations should be reviewed to take account of the pressure, close competition and professionalism of the sport today.
Viimati muutis veteran, 06 Juun 2004, 07:09, muudetud 1 kord kokku.
veteran
Täna on siis selline naljakas stardijärjekord:
Beres
Gardemeister
Schwarz
Sola
Grönholm
Märtin
Vovos
Tuohino
Stohl
Panizzi
Carlsson
Duval
Loeb Rovanperä
Solberg
Sainz
veteran
Wilsoni jutu järgi oli Markko eile proovinud uute TDE rehvide sobivust ja amorte,täna pidi kõvemini kihutama, aga ma kahtlen,kas ta ikka nii teeb.Stiimulit eriti ju pole.
veteran
WRN tõi välja ka eilse päeva SupeRally järjestuse. Ehkki see kellelegi punkte ei anna,oleks eilne paremusjärjestus:
3
M SÉBASTIEN LOEB
Citroen Xsara WRC F 1:35:41.0 --:-- 1:35:41.0 **:**.*
2 6
M HARRI ROVANPERA
Peugeot 307 WRC FIN 1:35:57.5 --:-- 1:35:57.5 +16.5
(+16.5)
3 8
M FRANCOIS DUVAL
Ford Focus RS WRC 04 B 1:36:10.0 --:-- 1:36:10.0 +29.0
(+12.5)
4 1
M PETTER SOLBERG
Subaru Impreza WRC 2004 N 1:35:54.7 00:30 1:36:24.7 +43.7
(+14.7)
5 4
M CARLOS SAINZ
Citroen Xsara WRC E 1:36:45.7 --:-- 1:36:45.7 +1:04.7
(+21.0)
6 7
M MARKKO MARTIN
Ford Focus RS WRC 04 EE 1:37:26.5 00:10 1:37:36.5 +1:55.5
(+50.8)
7 16 DANIEL CARLSSON
Peugeot 206 WRC S 1:37:52.4 --:-- 1:37:52.4 +2:11.4
(+15.9)
8 9
M GILLES PANIZZI
Mitsubishi Lancer WRC04 MC 1:38:18.6 --:-- 1:38:18.6 +2:37.6
(+26.2)
9 18 MANFRED STOHL
Peugeot 206 WRC A 1:39:04.3 --:-- 1:39:04.3 +3:23.3
(+45.7)
10 14 JANNE TUOHINO
Ford Focus WRC 02 FIN 1:39:36.0 --:-- 1:39:36.0 +3:55.0
(+31.7)
Antilera
Postitus Postitas Antilera »
hommikust
johunn
Postitus Postitas johunn »
Märtinil võrreldes bossega kohutavad splitid esimeses... üldse kõige aeglasem praegu :S
veteran
Hea et keegi üleval,muidu pomisen siin omaette. Markko algus kahvatu.Kas pole sõiduisu või mingi muu probleem :shock:
Antilera
veteran kirjutas:Wilsoni jutu järgi oli Markko eile proovinud uute TDE rehvide sobivust ja amorte,täna pidi kõvemini kihutama, aga ma kahtlen,kas ta ikka nii teeb.Stiimulit eriti ju pole.
vaadates praegu MMi ja Bosse edenemist, ei saa sugugi öelda, et MM täna tempot on lisanud. pigem vastupidi. 3. splitis juba -37 sekki Bossele.
veteran
Duvalil võimas algus
Antilera
siin tuleb ikka 1 min. kaotust. see ei saa enam motivatsioonipuudusega kah vabandatav olla. kas on võimalik, et probleemid MMi fordil? aga sel juhul probleemid kohe stardist alates
veteran
Antilera kirjutas:siin tuleb ikka 1 min. kaotust. see ei saa enam motivatsioonipuudusega kah vabandatav olla. kas on võimalik, et probleemid MMi fordil? aga sel juhul probleemid kohe stardist alates
Mulle tundub,et see võib olla väikese streigi moodi. :twisted:
Antilera
veteran kirjutas:
olen täitsa nõus. kuuldavasti polnud markko ise üldse sõitmisel enam mõtet näinud.
Antilera
liidrid väga ühes tempos alustanud täna :) ja MM lõpus ikka vajutas pisut vist
mees lõunast
Postitus Postitas mees lõunast »
vat aga sola sõitis küll hästi ja üleüldse see mitsu vist ühe kahe katse auto on,kiirust vast veel on aga stabiilsust mitte
ralli ei ole enam see!puhka rahus kallis sõber!
veteran
Markko jaoks oleks vist parim lõppjärjestus,kui keegi enam ei katkesta:
Duval
Rovanperä
Solberg
Loeb
Antilera
oi mehi lõunamaalt veel üles ärganud? duval on natu kiirem praegu loebist olnud aga liiga vähe. ei taha kellegile halba aga praeguse seisu juures oleks küll juba parem kui loeb katkestaks. muidu saab liia palju punkte.
Antilera
oiha andke andeks minu eksitus - loeb oli ikka kiirem kui duval
Antilera
Rovis tahab huvitav olla ja ei näita aegu. kardan, et asi lõpeb nii halvasti, Solberg
Loeb
Rovis
Duval
need 8 punni oleks küll liiast loebile. ei tea kas duvalil on käsk kindlad punktid koju tuua või ongi ikka niipalju aeglasem?
Antilera
veteran ütle sa kah nüüd miskit. muidu siin tõsiselt jamaks monoloogiks kisub
mees lõunast
märtinil vast selle pärast tuju kehv,et hr wilson käskis duvali poisil
punktide peale sõita,aga mitte võidelda loebiga koha eest.
