Rallifoorum Challenge Online 2007 Europe vs Estonia Round 2 05.12.2007 rules:
1. The game is played only with PS2/PS3, online in central-station, with WRC Evolved game and WRC cars. Choice of WRC car is free.
2. There will be 16 events.
3. The starting interval is 10 seconds. The recommendation is to start individually.
4. Each driver has only one attempt (1attempt) per each SS.
5.1 Super Rally System (SRS) - When you are taking part in the rally, no matter which room (SS - SpecialStage) you are in, when you fall offline or you leave the game (SS - SpecialStage), you will receive a penalty: first time from the stage +30 seconds. You can only re-enter the room (SS - SpecialStage) if conditions in rule 5.2 are met. If you have left the room (SS - SpecialStage) when 'racing' the stage, you can only go to the next room (SS - SpecialStage) and continue the rally. Referees are allowed to re-enter, but not allowed to drive.
5.2 Restart-rejoining - If you fall offline when entering the room (SS - SpecialStage) or the game freezes BEFORE you begin racing, you are allowed to re-enter the room (SS - SpecialStage). If you don't make it back to the room before it is 'closed', then you will receive a penalty: first time from the stage +30 seconds. When your lobby status changes to 'racing' rule 5.1 will apply.
TIP: If you finish the stage and have a PS 'freeze' try to estimate how long it will be until the last driver has finished before rebooting the PS. Your finished time will still be displayed on the final screen even if you are 'frozen' but not if you have rebooted too soon. Only driver times recorded on the final screen are valid otherwise rule 5.1 applies.
6. To get the result from the EU vs EE rally and score points, You either have to finish or use SRS (SuperRallySystem) and finish at least 12 SS (SS - SpecialStage). When You don´t finish 12 stages, You´re stage times will be cancelled and you´ll get a retirement.
7. The times of the drivers are protocolled by the referees. Protocol - after the SS/end of the room, a table with the driven times will appear to the TV screen. The referees will make a screenshot from that table. When the driver doesn´t have the times in this protocol, you will get exactly the same penalty what is mentioned in point 5!
8. The referees are Mr.Pants* RF1, Riho P. RF1, Milor II RF1, Ludooowrc RF2, Krusa* RF2, Riho M. RF2. Referees will watch for drivers having connection problems when entering the room, 'freezing', falling offline or leaving the room. There will be, at least, 2 referees in each room. Referee1 will begin the stage, drivers are then free to race. Referee2 will watch for driver 'freezes' before they begin racing. When referee1 has finished referee2 will race. Asterisked referee is main referee.
9. The driving aids are allowed.
10. The cheats are forbidden. When you are cheating, you´ll get a lifelong ban from RFCO.
11. EU vs EE Rally Round 2 is held on 05.12.2007 at 21:00 (9.00PM) (GMT+2) the name of the host are "RF1" or "rf1" / AND / 23.15 (11.15PM) the name of the host are "RF2" or "rf2". Teams will be split between the rooms. Team Captains will notify drivers about which room they will start in. Password will be sent in private. The times will appear under the topic: RFCO Europe vs Estonia Round 2.
12. One start/room rule - You can start the rally only once, either at RF1, rf1 OR RF2, rf2. When you appear on both starts/rooms, your times for that stage-or rally will be cancelled and you will get a retirement. If the driver continues to ignore the "One start rule", then he/she will be banned. This point doesn´t apply to the referees but they too can only start one race.
13. Point system: 1.-25p, 2.-20p, 3.-16p, 4.-13p, 5.-11p, 6.-10p, 7.-9p, 8.-8p, 9.-7p, 10.-6p, 11.-5p, 12.-4p, 13.-3p, 14.-2p, 15.-1p, 16.-1p, 17.-1p, 18.-1p, 19.-1p. 20.-1p, 21.-0, 22.-0p, and so on with 0p. All drivers are eligible to score points for the manufacturer/team.
14. Organizers are allowed to change the rules. Organizers are allowed to cancel the drivers times, eliminate the driver from the race, give the drivers penalties or ban them from RFCO, when something is not in accord with the rules or when the driver is not acting like a real sportsman.
Organizers: Krusa & Mr.Pants.
Rallifoorum Challenge Online 2007 Europe vs Estonia round2 reeglid.
1. Sõidetakse PS2/PS3-ga, online-s Central Station-s, WRC:Evolved mängu ja WRC autodega. WRC auto valik on vaba.
2. RFCO EU vs EE võistluse katseid(SS e.katse) on 16.
3. Igale SS-le e.katsele starditakse 10-ne sekundeliste vahedega. Soovituslikult startida eraldi.
4. Ralli sõitjal on üks võimalus e."1attempt" iga SS-i peale.
5.1 SuperRalliSüsteem (SRS) - Ralli ajal mis iganes viisil sõidetavast toast (SS-st e.katsest) ja online-st välja kukkumisel või minemisel protokollitakse sõitjale katsel esimese piloodi aeg +30 sekundit. Välja kukutud tuppa (SS e.katse) ei ole lubatud tagasi tulla (välja arvatud p.5.2), rallit tuleb jätkata järgmisest toast (SS-ist e.katsest). Kohtunik võib tuppa (SS-le e.katsele) naasta, kuid ei tohi sõita.
5.2 " Restart-rejoining" - Kui ralli ajal tuppa (SS-le e.katsele) tulles või enne rajale (SS-le e.katsele) minekut, online katkeb/mäng jookseb kokku vmt., siis on lubatud tuppa (SS-le e.katsele) tagasi tulla. Kui tuppa (SS-le e.katsele) tagasi ei jõua, siis protokollitakse sõitjale katsel esimese piloodi aeg +30 sekundit. Käesolev punkt ei kehti alates sellest hetkest kui, piloot on juba rajal ja toa lobby-s on näha tema nime taga kirjet "raceing".
VIHJE: Kui oled lõpetanud sõidu, nime taga on kirje finished ja mäng jookseb kokku, siis arvuta kokku kui palju aega jäi toa (SS e.katse) lõpuni. Kui end enne screen-i tegemist välja ei logi, siis on võimalus, et jääd veel sõidetud toa (SS e.katse) scriinile ja aeg läheb kirja.
6. Selleks, et saada katselt tulemus kirja ja teenida punkte, peab saama protokollitud kuusteist(16) katset(SS-i) või kasutama SRS-i(SuperRalliSüsteemi) ja saama protokollitud vähemalt kaksteist(12) katset(SS-i). Vastasel juhul võistleja ajad tühistatakse ja loetakse katkestanuks.
7. Võistlejate ajad protokollivad kohtunikud. Protokoll- SS-i/toa lõppedes ilmub ekraanile paremustabel sõidetud aegadega millest tehakse "scriin". Juhul kui sõitja aega ei ole protokollis käsitletakse seda kui p.5.
8. Kohtunikud on Mr.Pants* RF1, Riho P. RF1, Milor II RF1, Ludooowrc RF2, Krusa* RF2, Riho M. RF2. Kohtunikud jälgivad kas sõitjatel on tuppa (SS e.katse) tulemisel ja rajale minemisel online probleeme. Igas toas (SS-l e.katsel) on vähemalt kaks kohtuniku. Kohtunik1 teeb toa, siis on sõitjatel õigus minna rajale. Kohtunik2 stardib peale kohtunik1 finisheerumist. Tärniga kohtunik on peakohtunik.
9. Lubatud on juhi abid e. Driver Aids.
10. Keelatud on kasutada Cheat-e. Vastasel juhul antakse eluaegne võistluskeeld RFCO-s!
11. Ralli etapi päev on 05.12.2007.a. algusega kell 21.00 - toa nimi RF1 või rf1 ja 23.15 - toa nimi RF2 või rf2. Meeskonnad jagatakse tubade vahel pooleks. Meeskonna kaptenid annavad sõitjatele teada kes millises toas stardib. Parool saadetakse kõigile eraldi privas. Parooli edasi andmine kolmandatele isikutele ei ole lubatud. Ajad ilmuvad RFi järgneval päeval "RFCO Europe vs Estonia round2" teema alla.
12. Ühe stardi reegel- võistlejal on õigus alustada rallit vaid korra, kas RF1, rf1 või RF2, rf2 toas. Mõlemasse tuppa/starti ilmudes tühistatakse võistleja käimasoleva katse-või ralli ajad. Ühe toa reegli korduval eiramisel antakse piloodile võistluskeeld. Punkt ei puuduta kohtunike.
13. Punktisüsteem: 1.-25p, 2.-20p, 3.-16p, 4.-13p, 5.- 11p, 6.-10p, 7.-9p, 8.-8p, 9.-7p, 10.-6p, 11.-5p, 12.-4p, 13.-3p, 14.-2p, 15.-1p, 16.-1p, 17.-1p 18.-1p, 19.-1p, 20.-1p, 21.-0p, 22.-0p jne 0p . Meeskondlike punkte toovad kõik meeskonna piloodid.
14. Korraldajatel on õigus muuta reegleid. Korraldajatel on õiges võistleja tulemus tühistada, võistluselt kõrvaldada, jagada trahvisekundeid või anda võistluskeeld, kui see ei vasta ülaltoodud reeglitele või on ebasportlik.
Korraldajad: Krusa & Mr.Pants.
WRC:Evolved RFCO 2007 EU vs EE round2 events/katsed:
Team standings/Meeskondlik punktitabel:
Drivers standings\Individuaalarvestuse punktitabel:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
Special Stage wins per driver/Katsevõidud individuaalarvestuses:
1.
2.
3.
4.
5.
6.
Special Stage wins per team/Katsevõidud meeskondlikus arvestuses:
RFCO: WRC:Evolved - Europe vs Estonia maavõistlus round1 28.06.2007 tulemused/Europe vs Estonia international rally-match round1 results: link
