Mehhiko osalejate nimekiri!
http://www.rallymexico.com/competitors. ... %20Entries
WRC autosid on 16, mis on üsna rahuldav, arvestades, et tegu on väljaspool Euroopat toimuva ralliga. Kuid kokku on osalejaid vaid 44.
arz
Statistik
Postitus Postitas arz »
Tõsine jwrc ralli on tulemas, tervenisti 5 masinat kohal. Tundub et see aasta jääb sellele sarjale viimasex
mrali
Postitus Postitas mrali »
Mehhiklastel mingi Peugeot 206 sari väga popp,enamik kohalikke just nende autodega rajal.
nimh
Postitus Postitas nimh »
arz kirjutas:Tõsine jwrc ralli on tulemas, tervenisti 5 masinat kohal. Tundub et see aasta jääb sellele sarjale viimasex
Tegelikult tuli jwrc-s osalejatel 1 etapp vabal valikul vahele jätta. Ära ei jää midagi niisama.
Aastal kaks tuhat kuuskümmend
Reactions: 21
Mehhikos sõidavad Fordis meeskondlikele punktidele Toni Gardemeister ja Daniel Sola. Eelmine aasta võitis Sola seal N rühmas Roman Kresta ajab siis taga individuaalseid punkte.
Markko kommentaar Mehhiko ralli kohta:
"Mexico is a very nice rally which I like a lot,” said Markko. “In some ways I was quite lucky to win there last year, but in rallying you sometimes have good luck and sometimes bad luck, so it all becomes equal in the end. The stages are quite varied, with slow, fast and medium corners, but there is no one characteristic that makes México different from all the other gravel rallies. I would just describe México as a typical gravel rally which is a good thing, because there is nothing special to catch you out. I would love to win again this year, but it will be very difficult; more difficult than last year. I still have a lot to learn about the car and the tyres, but we are making progress all the time. México is the first 'normal' event of the year, as Monte-Carlo and Sweden are very different to anything else, so I think we have a good chance of doing well."
Markko räägib, et Mehhiko on kena ralli, mis talle meeldib. Eelmise aasta võit oli puhas juhus, aga rallis vahest juhtub, et on head õnne ja halba õnne. Katsed on vaheduvad, on aeglaseid, kiireid ja vahelduvaid kurve, aga pole ühtset eripära, mis eristaks Mehhiko katseid teistest kruusarallidest. Mehhiko on tüüpiline kruusaralli, mis on hea, sest siin pole midagi erilist, mis võiks endast ohtu kujutada. Ta tahaks väga võita ka see aasta, kuid see on väga raske. Palju raskem kui mullu. Tal on veel palju õppida auto ja rehvide kohta, kuid nad liigume pidevalt õiges suunas. Mehhiko on esimene "normaalne" ralli see aasta, kuna Monte ja Rootsi on väga erilised, seega ta arvab, et neil on hea võimalus siin korralik tulemus saada.
Allikas: rally-live
Kohmakas tõlge minu poolt :P
Möödunud nädalal tehti teatavaks meeskondade teised sõitjad Mehhikos:
http://www.fia.com/mediacentre/Press_Re ... 05-01.html
Prantsuse meeskondades muudatusi ei ole. Nagu juba varem siin teemas mainiti võtab teise piloodi koha Fordi meeskonnas seekord sisse Dani Sola. Subarut roolib Chris Atkinson, Mitsubishit Gilles Panizzi ja Skodat Jani Paasonen.
kaits
Postitus Postitas kaits »
Ilmaennustus lubab Mehhiko ralliks vihma
http://sport.etv.ee./index.php?0511688
Rasmus
Postitus Postitas Rasmus »
See on vesi Pirelli veskitele :)
Sellel ning eelmise aasta kiirusel tuginedes võib karta et Solberg teeb uuele autole korralikud ristsed.
Rasmus kirjutas:See on vesi Pirelli veskitele :)
Solbergi kohapealt ei julge sõna võtta, aga vihmaga on esimestena startijatel eelis. Mis on vesi ka Markko veskile.
Vaatasin piltidelt, et Mexicos on Märtini autole unustatud "ä" täpid kleepida:P
Reactions: 21
Kristo kirjutas:Vaatasin piltidelt, et Mexicos on Märtini autole unustatud "ä" täpid kleepida:P
Kus kohas sa neid pilte juba nägid? Äkki viskad lingi ülesse :wink:
Grönholmile pole ka täppe pandud :( Peaks kaebuse saatma :twisted:
KuriUss
Postitus Postitas KuriUss »
Mis seal ikka kaevata. FIA keelas ilmselt täpid ära :wink:
Reactions: 21
Aga selle eest on Rovanperal (Rovanperä) täppid peal kui ma õieti vaatsin.
nimh
Kõige pealt, mis võimalik tuleb kaalu kokku hoida.
Eks ta ole jah, kaalujaotus on ikka kõige tähtsam. Ju nad panid need täpid siis põhja peale, et kui auto ümber kuudi käib, siis on ilusti näha :lol:
WaltS
Postitus Postitas WaltS »
... ja Peugeot on ainus kellel on ka kaardilugeja nimi olemas.
küll tiba väiksemalt, aga olemas :)
http://img180.exs.cx/img180/4825/dsc015151dz.jpg
ja mida see 6 sellel pildil tähendab? kas 6 käiku taas?
Reactions: 21
WaltS kirjutas:... ja Peugeot on ainus kellel on ka kaardilugeja nimi olemas.
Tundub nii.
