Rootsi ralli osalejate nimekiri
http://www.swedishrally.com/site2005/eng/anmalda.htm
Hetkel on nimekirjas 19 WRC masinat, 18 N masinat (2. N3 ja 16. N4) ja 2 JWRC masinat.
Päris hea ralli peaks tulema tegelt, aga kas keegi teab midagi rääkida TRACEY George kohta?
Tracey on iirlane, kes sai selle hooaja alguses endale 206 WRC, tegu on EVO 1 mudeliga, ehk siis 206 kõige algelisema versiooniga, mis kuulus varem Kronose meeskonnale ja millega 2003. aastal sõitis Euroopa meistrivõistlustel venelane Jevgeni Vasin. Kahjuks on Tracey nagu kõik iirlased rohkem kodus asfalt teedel ja isegi seal pole ta märgatavat edu saavutanud. WRC autodest peaks ta olema igatahes üks aeglasemaid.
Mitsubishi teises autos juht ja kaardilugeja TBA...
Any FIA competition licence-holder wishing to take part in the rally must send the entry form duly
completed to the Rally Secretariat (full address, telephone, fax number etc.), before the closing date which will be
specified in the supplementary regulations. Details concerning the co-driver can be sent in up to a further date to
be specified in the supplementary regulations.
If this application is sent by fax, the original must reach the organiser within 7 days following the close of entries.
No change of competitor/entrant may be made after entries have closed.
One member of the crew may be replaced with the agreement of:
- The Organisers, before the start of the administrative checks.
- The Stewards, after the commencement of these checks and before the publication of the list of crews eligible to
take the start.
Only the FIA can authorise the replacement of both crew members.
Et siis minuarust oleks Mitsubishi pidanud kirjutama vähemalt piloodi nime? Või nagu Ford tegi suvel Pirelli rallil, et registreeris Märtini koos Ahoga ja kui vaja siis sai ühe neist vahetada (Märtini Tuohino vastu siis).
take the start.
d) The name of the first driver. The driver of the second car may be changed for each of the rallies in
the Championship. The name of the second driver must be notified to the FIA no later than 5 weeks prior to
the start of the Rally concerned, save when the interval between rallies is less than 5 weeks, in which case
the second driver must be nominated within 24 hours of the finish of the preceding rally.
Autoralli MM-sarjas kehtivate reeglite järgi võib sarja registreerinud autotootja teise piloodi nime teatada 5 nädalat enne ralli algust. Kui eelmise ja tulevase ralli vahel on vähem kui 5 nädalat, siis tuleb teise piloodi nimi tulevasel rallil teatada 24. tunni jooksul pärast eelmise ralli lõppu.
Seega peab Mitsubishi teatama FIA-le teise piloodi Rootsi rallil hiljemalt 24. jaanuaril.
- Reactions: 21
Nüüd on asi selge Tänud.xaus kirjutas:d) The name of the first driver. The driver of the second car may be changed for each of the rallies in
Eriti kõva on see et noor Mölder sõidab
Aga selline küsimus ka, kas kellegil siinsetest foorumikasutajatest plaanis Rootsi vaatama minna ka on? Kui on siis mulle veel eelmine nädal pakuti 6st kämpa maja umbes 30-40 kilti ralli tehnilisest pargist eemal, st siis Raada lennuväljast. Ise lähen ja ööbin ka seal, aga kui kellegil huvi ja ööbimist pole siis võin veel uurida kas majake vaba.
lähenka Rootsi, aga elamine peaks olemas olema. Kuuldatavasti ca. paar kilomeetrit ralli keskusest.Tan kirjutas:Eriti kõva on see et noor Mölder sõidab![]()
Jah, teise tootjate arvestuses punkte jahtiva peab FIA-le teatama 5 nädalat varem. Võistlusele registreerima peaks ikka nagu juhendi järgi.xaus kirjutas:Autoralli MM-sarjas kehtivate reeglite järgi võib sarja registreerinud autotootja teise piloodi nime teatada 5 nädalat enne ralli algust. Kui eelmise ja tulevase ralli vahel on vähem kui 5 nädalat, siis tuleb teise piloodi nimi tulevasel rallil teatada 24. tunni jooksul pärast eelmise ralli lõppu.
